Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
what is the best way to wire a bathroom extractor fan, do take the power from the light rose straight to the fan or shall i have a fused spur from the light then to the fan.
You will need a double-pole switched fused connection unit so that it will disconnect both live and neutral when you switch it off.
Place it on the wiring between the light and the fan.
