I am currently in the process of renewing my brothers bathroom. Upon taking the bath out i have found out that the basin and bath waste both goto drain of the same waste pipe ( bathroom is on groundfloor). The basin runs along the wall in 32mm where it then T's into the 40mm waste from the bath. Now i know this is incorrect installation as they should have individual waste to drain. If i left this in place i would get "gurgling" sounds when the bath/basin was emptied (induced siphonage?). I was wondering if i increased the diameter of the pipework to 40mm, installed an anti vac trap on the basin would i be able to by pass this problem. If not could you suggest an alternative method for me. Another hole through the wall isnt really an option as space is very limited.
Any advice/help much appreciated.
