My existing system is an S-Plan. While having a lot of CH pipework changed, I am having the bathroom radiator removed from the heating zone and onto its own summer circuit, essentially a third zone but without a valve. Then, whenever either the heating or hot water are being pumped, the rad will get warm, the main benefit being to have a bit of heat to dry the towels even if the main heating doesn't cut in.
I would like a TRV fitted to the bathroom radiator, my reason being to stop the temperature in the bathroom from being too high.
My heating engineer says not to fit a TRV, because it defeats the objective of the circuit. When the ambient temperature is high, which is the time when the heating is off, the bathroom rad would not heat up. That is a valid point.
However, on very hot summer days I would not necessarily need much, if any, heat from the rad. It's the in-between such as cooler summer days that I see the circuit being of benefit.
For info, the bathroom circuit will not be acting as a bypass, nor does it need to as a separate bypass with ABV is being fitted to replace the existing permanent bypass.
Any views on whether to go for the TRV or not?
