Bathroom tiling almost complete but advise needed
  • Thread starter Thread starter SL
  • Start date Start date
SL
17 Jun 2007
Suffolk
On one wall I have 2" mosaic tiles, that are not glazed on the edges and would prefer not to use a plastic strip on the top as I can not find a colour that matches / looks right.
Are there any other options? Tiles are 8mm thick. I was thinking about cutting the tiles at 45 mitres, as if doing a corner. Not sure what this would look like or how difficult it would be to do.
How about a very thin carefully applied line of gloss paint. I used this to cover over a chipped tile a couple of years ago and you could only spot it when it was pointed out
Mix up some grout a bit thicker than normal, apply to the corner then as it firms up use the grout float to rub it into a bull nose, BAL widejoint is the best for this but I have done it with Mapie Ultracolour as well.
Not really close enough, but did around this window with the above method
Jason
