Baxi Bahama 100 Burner Neon flickers
1 Dec 2006
London
When the boiler stopped firing I used the troubleshooting guide that indicated I should check the CH Flow Switch. It was open circuit, so I replaced it, but still no spark.
What I don't understand is:
Power off, wait 10 mins then turn on - position DHW only
Turn Hot Water tap on.
Burner neon flickers once.
The troubleshooting guide doesn't cover this situation - why does the neon flicker only once?
Checked the Plate Heat Exchanger - it's not impeding the flow. Neither is the inline filter (I removed it).
Don't know what else to do to diagnose the problem.
Regards
Chris
