Hi, moved in this summer but now winter has hit we are having trouble with the DHW/CH controls, Ive done a small amount of fault finding,
HW stat does call/power off at temp
Remote CH stat bats changed and does call/power off signal at temp.
The CH stat has a timer built in plus we have a separate HW timer, looking at the wiring (2010 Baxi solo boiler). My madness stats as even if the CH is calling for heat, if the DHW is on timed or off the boiler wont do heat. boiler is only feed by perm N, earth and Switched live from DHW timer, SL from CH looks to link straight to 3 port M valve. any advise welcome ie should I link the Sl from the CH with the Sl from the DHw timer-boiler?
