I have a Baxi Solo 3 60 PF (41-075-07). It has been working fine for a few years now, but has recently started playing up.
What I think is happening is as follows:
First thing in the morning HW and CH come on together all works OK.
At some stage both turn off normally(everything up to temperature).
The CH won't come back on when room temp drops - all the lights come on boiler, fan and pilot, BUT Burner and its light don't.
(I think it does the same the other way round too but harder to tell, i.e. if CH is up to temp then it doesn't heat HW)
If I manually turn off HW from the control panel, then the CH kicks in and I can then also turn HW back on and it works again.
I am guessing I either have a duff timer, or the boiler is getting confused by thinking that when CH is up to temp it doesn't need to heat the HW and vice versa.
Any help greatly appreciated.
Oh forgot to add, pump and motorised valve are working fine.
