Beko American fridge freezer water collecting
20 May 2015
Birmingham
model: ASD241B
We've had this fridge-freezer for four years. Recently over the last few months, there's been water collecting under the salad trays. It needs mopping up every few weeks. I can't spot an obvious drain hole that needs cleaning.
Any ideas?
If you look at the compressor at the back there should be a tray on top of it that collects the water which is evaporated by the heat of the compressor. There should be a tube hanging into the tray that carries the condensate from the fridge, you may be able to trace it back to a drain hole inside the fridge or poke a wire up it to clear any blockage. There should be a drain of some sort somewhere inside to prevent the problem you are having.
Same problem.
Looked in rear , low down and could see drain tube . No drips and dry underneath
Switched off. Removed contents including shelves. Ours has two screws at bottom of rear panel. Removed those. Pull panel out on one side then lift out. This revealed central drain hole. Cleared out with tube, syringe, hotwater and salt until drips ran then stopped at rear.
Reverse to refit panel etc.
