Belfast Sink Waste
j03
21 Mar 2006
A friend recently gave me an old Belfast sink, similar to, but a bit larger than this one:
I've been looking for waste and plugs for it but can't see how any that I've seen will work because of the overflow outlet in the hole at the bottom.
I would ideally like a basket strainer but none of the ones I can see on the web look as though they have any inlets for this outlet.
Can anyone point me in the right direction if they know anywhere that sells them and also explain how the water from the overflow gets expelled?
Thanks a lot.
the overflow outlet like any sink works by emptying the water to a point below the plug
in this case only just below the plug so it wouldnt be possible to fix a wire strainer as it would block the overflow
Ok thanks, so do I need something like this. It's advertised as a Belfast sink waste:
Inch and a half slotted sink waste ;) and tell the shop it`s for a belfast sink ...take a measurement of the hole dia. with you ....needs to be a plumbers merchant or old hardware shop.......and you`ll need a plastic washer to go under the nut on the bottom of the sink.....you need exactly what you pictured as I was typing :LOL:
try and find one with the large steel back nut as the plastic ones are useless
Thanks for the help guys, much appreciated.
