    Dismiss Notice
best Fall lines for a new patio
Discussion in 'Building' started by zuber ali, 14 Aug 2021.
  1. zuber ali
    zuber ali
    30 May 2021
    46
    Thanks Received:
    Country:
    Hi All
    Looking to lay some slabs down for my new patio and im not too sure on fall lines. when working on fall lines should you calculate from the lowest point you want and work your way back to the highest based on the gradient.
    I would also like to know what would be the best fall line option to use. I have added a image in link below with two potential options, A and B denoted by the red and blue lines.
    I would like to do option B as it seems more simple, but im not sure if the slope would be too great over the full 7m run (i.e at the end of the 7m run my i have grass which would be higher than the patio). in which case option A is better?
    hope this makes sense
    https://ibb.co/RcJWGsT
  2. Sponsored Links
Loading...
Share This Page
