best flange?
27 Nov 2006
London
hi all
i am fitting a twin impeller 1.5 shower pump,to a standard gravity fed system,the pump is positioned at the base of the h/w cylinder and there is no neg head.
what is best/easiest flange to fit?,essex,surrey,warix, dazey,
do you have to fit a flange?
any recommendations.
thanks
IMHO, Essex, but you need to use the correct diameter hole saw.
Although I've never seen a dazey.
No, as long as you don't mind replacing the pump when cavitation sends it to an early grave.
Fit an Essex flange.
If your not fitting a flange it has to be the first draw off and at least 6 inches below the tee for the open vent
:rolleyes: i got all excited when i saw this post.
Imagine my disapointment when i saw it was not about ...well...flange
What do you think an Essex flange looks like John? :D
You should be chuffed to get that one right! :D
You could do it like this at a pinch but the riser from the cylindrr will lose heat by convection.
That Salamander flange is a Surrey. Wessex usually fit the pipes better.
