Hi there,
our central heating has stopped working completely, have reset the timer, checked the thermostat is set etc.
Hot water is still working completely as it should be when needed.
The main syptoms / indications I have are that when all hot water taps are OFF, AND heating ON or OFF (i.e. in either JUST d.h.w mode OR d.h.w + C.H mode) we have lights 1 and 3 flashing alternately.
This is the usual code that comes on when normal hot water is being demanded and used. - but to re iterate this is the code I'm seeing at all times unless boiler is turned off. - (I've checked no taps are on!)
During this period the boiler isn't lit/ fired up however there is a noise which I suspect is something like a Fan or a pump - its the same noise that you get when you are using central heating normally when the temperature within the boiler has reached the set value and therefore stops the flame for a short period untill it needs to be re ignited.
No matter what I try I cannot get the central heating to come on.
I've felt the pipes under the boiler and the far left pipe which i believe to be the c.h pipe is not warm, the very top of it is marginally 'not cold' but maybe it is just taking heat from the d.h.w pipe which is next to it?
the pressure on my gauge is 1.1 as the manual suggests.
does anyone know if there is anything I can do to test various things? we have previously (over a year ago) had a replacement c.h. temp probe but the symptoms were totally different from the above!
greatly appreciate any advise.
thanks
Chris
thanks
Chris
