biasi riva compact m90e.32s
6 Jan 2011
Hampshire
Hi all,
boiler was fitted in feb 2004, and been fine until new years day. i had no power going to the boiler at all. i found that the 1.6amp fuse had blown on the main pcb, i replaced this and got the power back on but the boiler was still faulty. i've inspected both pcb's and found that the full sequence ignition device is the problem as there is a component on the board that has blown. it's the honeywell type pcb. i've found a replacement pcb but it's the FM30 type, is this ok to replace the original and can i change it myself or will it need to be a plumbers job, thanks for any reply dave
