Hey..in the middle of a build and there is a lot of block bonding involved where new walls meet old.
Ive most of it done and im wondering how often you should be cutting into existing walls.
They are cavity walls meeting cavity walls @ 90 deg.
So far i have been doing one block on each course and alternating from inner to outer leaf as i go up, but am wondering if it would be acceptable to bring in both courses @ once...then skip a course then both again etc etc....this i think would be much easier as i could use my disk cutter as the holes would be big enough to justify using it(12" disk is too big when your cutting 5" wide only)
Cheers,
Marty.
Cheers,
Marty.
