Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi i'm quoteing to ply out a loft aprox 80 sqr m.
The client wants to use it for light storage. Need to know what depth of ply to use. Joists are aprox 350mm apart.
First thing, run 2x2 battens, screwed down into existing joists at right angles. adds strength and enables wires and pipes to be circumvented, plus will leave more space for insulation.
18mm T&G chipboard will be cheaper at about a fiver a sheet. If ply is preffered you will get away with 12mm for light storage, although thicker won't hurt.
When you say 'joists', are these actually strong enough to support a floor? Many loft joists are only strong enough to support the plaster ceiling underneath. Just be careful. 18mm t&g chipboard would be my suggestion.
