Boiler help needed please
16 Mar 2010
Manchester
Hi all.
I own an ariston a/23 mffi combi boiler.
Its started leaking from underneath so i decided to investigate.
Ive found the leak. Its comming from the diverter valve. But not the diaphram end.
Its the opposit end where there lookes to be some kind of electrical device / switch or something.
Water is slowley dripping from in between the diverter valve body and that part. And it seems to do this mostly when the boiler fires up to heat the rads.
Is this repairable without having to replace the entire diverter valve ?
Ie. Could this be as simple as a failed seal at this point in the valve.
Any input / advice woud be really welcome.
