Boiler lockout
6 Jan 2006
Aberdeenshire
Camray 3 oil fired boiler. Ran out of oil yesterday, tank now filled. Boiler locks out, I assume due to air in the (single pipe) gravity feed line. I'm looking for the "vent port" on the oil line, to purge the line as described but not pictured in the instruction manual. Anyone got an idea where the vent port might be located?
cheers
under black slotted screw as you look at pump is blank.
crack open , fire up, loads of froth, tighten up.
filter may need bleeding, but 9/10 above works.
