boiler & low water pressure to shower
27 Oct 2006
Having read several responses in the forum, it seems apparent that the PCB is a common problem with these boilers. 2 of my neighbours have had their PCB's replaced and the guy fitting them said it was common with these boilers. So thanks for the info, at least it gives you a good start where to look or have discussions with the service engineer.
Regarding another issue, shower water pressure. It is pitiful, and virtually a dribble. the house is 6 years old and the shower is a mixer tap type. the boiler and pump is on the same level and the cold water tank is in the loft, so I do have a head of water. But it certainly has no power. What can be done to increase the power/force? I have briefly looked at fitting an independent pump into the line (hot water) but may just go for an electric one with guaranteed power.
Any suggestions?
