boiler overrun
25 Aug 2005
Dumfriesshire
i have had a new boiler installed in my mobile home by a corgi engineer, it is a 35kw alphacdc, the pump runs continously i was told it is too big, if this is so, can the burner be adjusted please.
Don't know if Alphas can be range rated down, but 35Kw :shock:
You must have a massive mobile home, this is enough to heat about 20 good size radiators :?
Hope you have a mobile gas line :shock:
pump should stop eventually but may take up to 15 mins. Are any of the rads hot?
I would personally get the installer back to commission the boiler correctly.
This is a combi boiler which is fully modulating but can't be range rated.
