bosch washing machine
17 Apr 2009
My Bosch WFF 1201 washing machine has stopped spinning. Any ideas please. thank you
Hi. I have replaced the brushes but still the machine does not spin. It is very awkard to get to the brushes. I had to place machine on side and then reverted to putting it upside down. When i removed the first brush as i was not aware what was going to come loose first, i did not notice which way round the tapered brush end should be refitted. If i have put the new one in the wrong way round, could this be enough for it not to start the machine spinning again?
ta :(
yes .if round wrong way it will not start
Easier to see what you are doing with the motor brushes if you unbolt the motor (turning the machine upside down can cause some problems for later)
When replacing the brushes check the commutator for damage and clean out the brush holders (they have a tendency to get clogged with dust preventing the brushes from moving freely)
