Bosch WFF1201 Drum not turning
18 Dec 2003
Good morning
Trusty Bosch WFF1201 that's washed a million loads has finally failed
It all runs except the drum doesn't turn at any point, the pump pumps, the water runs in but nothing happens when the drum should turn
It has been making an odd scratchy metal sort of noise for the last few weeks when the drum started to turn
My zero knowledge and limited reading suggests this might be the motor brushes rather than the belt
Is that about right? I was going to have a crack at the belt, is it reasonably easy for someone not stupid with basic tools?
And is changing the brushes reasonably easy?
And will these parts being available from the usual repairs type old fashioned shop?
phew, sorted
for anyone else, there's no need to take the back off and thentry and try and take the motor off
turn it upside down and it's all more orless straight forward from there
here's the post I found somewhere else that saved me
brushes are down to a stub
John Verity, in NJ
September 2007
Hi
This is the way I do it. It saves scrabbling about on the floor!
Switch off power, disconnect hoses, open pump housing to completely empty machine of water.
Turn the machine upside down onto a soft surface - eg a blanket on the floor, and carefully cut the cable tie holding the motor cable and splashguard to the motor body; disconnect the motor connector and earth spade to facilitate easy access to the more visible brush block. The brush spades disconnect easily, then the brushes are extracted by sliding each spade terminal inwards toward the motor spindle until the connector end is released from the block, then pull the other way to release the inward end - withdraw the spring/brush assemblies gently from the carriers. The brushes are clearly on either side of the motor spindle but see how they do not fit on a diameter of the motor axle but are inserted tangentially - the curve on the brush is polarised to take this into account - you want to have the wider carbon contact surface of the two fitting options possible. Reassembly is simple but make sure you do not reconnect the mains supply if any water has been spilled into the top of the machine... leave it for a day or so to dry out (I've never had such a problem but I have to say this!!).
You can test the motor using the spin cycle before re-installing the machine properly.
I gather there are two types of brush fitted - I've had no experience of the other type but it should be a service item.
Hope this helps. Regards
John
July 2005
fitted the new ones today and easy enough once you get the hang of it
man in the shop said rotate the drum gentley to check if the brush is in the right way round, good sound is good, bad sound is bad, first one went in the wrong way round and there's no mistaking the bad sound
the happy smooth purr of the faithful washing machine washing is bliss to the ears
Hi, I have the same problem. Replaced the brushes but the problem remains.
Any ideas?
Bob
Sorry but I don't understand
so i see.
I shall endvor to expalin
You have the same problem as tynan, so you followed what he posted (new brushes)
new brushes did not work for you, so you then asked tynan does he have any other ideas.
however tynan actualy first posted "My zero knowledge "
which to me means that tynan has no idea about washing machiens what so ever, other than what he has found on the internet. I.E. Change the brushes (which you have done)
so in conclusion don't ask tynan as he has no idea (No disrepect intened to tynan)
and also i suggest you read the forum rules, 6 would be a good place to start.
then when you have read forum rule 6
post again but with your own , non - hijacked topic
Any ideas?
Bob
I have had the same problem, including repacing the brushes not fixing it, so if anyone's still interested here's what I did a few years ago (and posted in FixYa, sorry):
There's an internal fuse in the motor which is not replaceable, but in emergency you could bridge this with some wire and see if it fixes the problem. If it does, you should get a new motor otherwise without a working fuse it might one day take out the rest of the washing machine, and maybe your house fuse.
