Bosch WFK 2401 Cloths Washer Won't Spin
24 Aug 2005
Our washer will fill with water and go through cycle but does not spin. If we jiggle the door switch we can get to spin. Do we have a bad latch, bad lock or something else? Help!?
____________________
moderator
moved as posted in "Electrics UK"
That is a fault with the washing machine
Door switch faulty?
YES
either the door switch is faulty or the frame has bent out of true causing it to not activate properly.
the first is easilly fixable the second isn't
