Hi , after noticing that my boiler was making a louder than usual droning noise while running , i first replaced the nozzle - no difference , then i decided to remove the top from the heat exchanger and cleaned the inside , there was loads of soot build up which i cleaned and hoovered, after removing the baffles i found that the bottom one was very warped , the middle and top ones were a bit bent but not so severe as the bottom , so could this be the cause of the droning noise ?
i also noticed there is no insulation on top of the heat exchanger should it be there ?
