can anyone help
i have a britony 80 1998 model was working fine until a few days ago.
it refuses to fire up when the hot water tap is turned on or the central heating
when the boiler is switched on the fan runs constant even with the hot water tap turned off , when the tap is turned on the pump starts working but there is no ignition and also the gas solenoids do not open. i have checked the following
Both flow valves were removed checked for ease of opertion and refitted.
Checked air pressure switch for continuity as per download for boiler.
Checked all fuses in pcb boards
Checked for dry joints on pcb
and still no joy, i don't understand why the fan runs all the time but if you pull off the wires to the dhw flow stat the fan stops?
