Broken Blue Bosch Drill
6 Dec 2005
Hampshire
Whilst doing a large amount of drilling into masonary my bosch 12v hammer drill had a slight unusual smell to it. After taking out the battery to recharge it and replacing it the drill totally failed. This is a two part query.
1) Any ideas where to get the drill repaired if it is possible to repair them, Im based north Hampshire.
2) Any ideas on the cause of the problem.
Did you take the newly flattened battery and charge it straight away? I'm only asking because you're not supposed to charge a hot battery. Maybe you killed it.
You get that smell when you're working a drill too hard - let it rest every once in a while to cool down.
Gcol
heeelllooo graystar and welcome :lol: :D
did you have a second battery to try the drill with!!!!!!
or are you unsure if its the battery or drill or a possible mixture off both
how old is the drill!!!!!!! is it withing g /tee period
i suspect repairs will be uneconomical
does your charger have a faulty battery indication!!!!
The drill battery is fine it works in the 12v drill/driver possibly a switch problem, I have resisted the temptation to take it apart and dropped it off at a repair shop, I await the bill.
