    Dismiss Notice
BT line tester
Discussion in 'Electrics UK' started by opps, 20 Jul 2021.
  1. AndyPRK
    AndyPRK
    4 Jan 2009
    5,850
    Thanks Received:
    589
    Herefordshire
    Country:
    A lot of electronic bells require the 3rd wire.
    As you say if phone has only 2 wires, that is the best indicator
  2. Sponsored Links
  3. JohnW2
    JohnW2
    28 Jan 2011
    47,859
    Thanks Received:
    3,119
    Buckinghamshire
    Country:
    I have to say, personally, that whilst I have known what was 'technically correct' from the start, I still very much think in terms of 0207/0208 followed by 3+4 and, indeed, I think that I still nearly always verbalise or write them as such.
    As you say, it doesn't really make any difference at all - except, I presume, for those who live in those areas (which I haven't for ~35 years),who I presume can dial just the 4+4 for calls within their (0207 or 0208) area.
    Kind Regards, John
  4. winston1
    winston1
    11 Jan 2010
    6,890
    Thanks Received:
    524
    London
    Country:
    Indeed they can for calls within their 020 area. (You still got it wrong at the end of the last line!).
    More to the point people who get it wrong try to dial 3+4 and wonder why it does not work.
    Incidentally I don't remember having to dial 11 digits at any time during the changeover except for calls outer to inner.
  5. JohnW2
    JohnW2
    28 Jan 2011
    47,859
    Thanks Received:
    3,119
    Buckinghamshire
    Country:
    I guess that illustrates how 'fixed' my thinking still is :)
    However, functionally speaking, I did not "get it wrong", witness my reference to their dialing "4+4". However. I agree that what I wrote in brackets was 'wrong' - I should either have written (like you have) "within their 020 area" or (which is probably what I really intended) "within their (020 7xxx xxx or 020 8xxx xxxx) area".
    Do I take it that, within the 020 area, this also works for 020 3xxx xxxx numbers (or any other 'fourth digit which may exist or appear)?
  6. winston1
    winston1
    11 Jan 2010
    6,890
    Thanks Received:
    524
    London
    Country:
    Indeed it does.
    • Thanks Thanks x 1
  7. SUNRAY
    SUNRAY
    28 Jul 2009
    5,092
    Thanks Received:
    381
    Kent
    Country:
    Ah that may very possibly have been the case depending on where you were, as exchanges 'changed over' at different times, accordingly different arrangements were in place at different times. However the publicity at the time was massive, as someone has already mentioned, so there should be no excuse for not knowing the 'official' situation.
  8. danechip
    danechip
    15 Sep 2010
    658
    Thanks Received:
    62
    Kettering, Northamptonshire
    Country:
    Oh how times change.
    My Wellingborough number was 0933 78671 to 0933 278671 to 01933 278671. We used to Call Northampton, we dialled 88 as a 'speed dial' Do those still exist?
    My old phone number in London as a kid 1984 (Grahame Park, Colindale NW London) 01 205 3750
    Working in Telco, Cable tele years ago, we did get ars£y neighbour who would refuse 2 feet of bush being used to install a neighboUr's services. On the odd occasion, we could have a wayleave in 4 hours, but we always got a return.
    And why do virgin offer less per month for a telco contract included (No wiring needed, it plugs directly into the 'modem' now. Powercut, phone line now useless.
  9. wgt52
    wgt52
    25 Apr 2016
    1,203
    Thanks Received:
    228
    Country:
    Short Access 'codes' (speed dial) went around the time (but before) of the national code change. They had to go as the codes were restricting the available number ranges in any 'phone area.
    • Thanks Thanks x 1
  10. Sponsored Links
  11. SUNRAY
    SUNRAY
    28 Jul 2009
    5,092
    Thanks Received:
    381
    Kent
    Country:
    About the same time mobile phones were all changed to 07..... IIRC
    • Thanks Thanks x 1
  12. opps
    opps
    16 Jun 2006
    4,973
    Thanks Received:
    793
    London
    Country:
    I appreciate your, and others' posts, but...
    The cables that were not connected to the 10 core cable coming out of the ground- I removed them.
    The old cable that supplied the Banham alarm was showing 48v. The customer asked me to remove it. He now has a 3G MODEM. I cut it back and used gel crimps on the two wires that trace back to the 10 core cable. The two remaining cables that run back to the 10 core cable but are not terminated to any fittings in the house, I did the same thing.
    I could not see why snipping a wire that is, for example 2m long, but not connected to anything other than the ground level BT cable would harm their network. We are talking about 2 cores being used, and not 4 pairs of twisted cable. If anything, I worked n the assumption that cross talk is more likely if old cables are running in to old properties and not terminated as close to the BT 10 core cable.
    If I am wrong, then please do provide links and I genuinely will read them.
    At the risk of sounding flippant, which isn't my intention, I appreciate that what I may have done is not legal, but I am not going to lose any sleep- unless someone can demonstrate that my actions have harmed anything. If that happens, I will take steps accordingly to mitigate any (potential) problems.
    • Like Like x 2
  13. bernardgreen
    bernardgreen
    3 Nov 2006
    25,372
    Thanks Received:
    2,523
    Bedfordshire
    Country:
    A telephone connection to the alarm suggests the alarm is ( was ) connected to a monitoring system. If the monitoring system contract has been terminated then I would expect the telephone line would have been discontinued / parked and dissed at the exchange.
    If the monitoring contract has not been terminated then if the monitoring system performs a routine line check then the system will probably flag up a line fault.
    • Like Like x 1
  14. SUNRAY
    SUNRAY
    28 Jul 2009
    5,092
    Thanks Received:
    381
    Kent
    Country:
    It sounds to me that you have been vigilant and careful with your actions. I very much expect your customer will hear nothing more from any officialdom.(y) from me.
    • Thanks Thanks x 1
  15. sparkymarka
    sparkymarka
    16 Feb 2011
    8,757
    Thanks Received:
    1,331
    Sheffield
    Country:
    3G modem ? Probably a dual com unit or other …. Soon find out when it flags up the secondary path is down …
  16. danechip
    danechip
    15 Sep 2010
    658
    Thanks Received:
    62
    Country:
    Just an afterthought working in cable. At the time, Wellingborough (01933) Had numbers starting, in 2, 4 and 6. Comtel numbers started with a 3. I installed a residential address, and they were given 01933 333 333. Why did the comms company not put that number up for bid. I understand the numbers were random, but come on ?? Perfect for a taxi or take away...
  17. opps
    opps
    16 Jun 2006
    4,973
    Thanks Received:
    793
    London
    Country:
    Banham moved the customer from a monitored service to a SIM based MODEM about 4 months ago.
    With regards to the termination at the exchange- I can't comment on that. I do not know if Banham use their own monitoring "station" or a third party. Nevertheless it was Banaham that disconnected the fixed wire MODEM and replaced it with a SIM based set up. I guess that it is possible that in X months the line would have been terminated at the exchange regardless.
    On the off chance that the customer had given me incorrect information- I removed the faceplate from the NTE5 box. The alarm keypad showed no signs of "distress".
Loading...
Share This Page
