budget belt sander which one
ceg
24 Oct 2005
Leicestershire
hi all
i'm busy sanding parquet floors with a belt sander all going well except the b&q pro belt sander i borrowed just stopped working.. took it to bits and cleaned out sawdust etc but nothing happening - any ideas on easy fix/what to check etc? before i go buy a replacement?
i also bought a makita beltsander 75*457 size and found this to be great - much lighter and easier to use (being female - lightness and ease of use helps!)
i'm looking for a probable replacement to the b&q one, any ideas on what to buy for approx 50quid..are any of the wickes own brand ones any good? or should i stick withthe b&q pro one... think its about 65 quid.. (they seem to have put their prices up as sure it was around 45!)
thanks to all in advance for any help/advice
Just used the wickes one (£40) 75 x 533 to sand back an oak wood floor for a friend. Worked a treat and has a 2 year warranty. I also looked at the b & Q version but it looked the same for £65 !
I got the B&Q one (pro) for £39. I just use them until they fall apart and then get a new one under warranty.
joe
the s.i.p. one from toolstation is ok. 29 squid . good build quality. errr and it sands a treat. 75x533
i must have wasted years at woodwork class at school with that stoopid cork block and some grit wrapped round it, :cry: :cry: :cry: :cry: :cry:
thank the lordy for all these gizmos :p
