Building a Porch - facing a wall
20 Jun 2006
Cumbria
I'm adding a small roofed porch to the front of my house - it'll be about wide 1.4m x 1m extending off the front of the house.
The house is pretty old so I'm planning on building an inner single skin block wall and then facing it with local stone. (The wall will only be half height so that a wooded frame can can sit on top with windows on both sides and slate roof on top).
Any tips on construction? I'm thinking 100mm wide block with dpm to first brick height, 30mm cavity and then approx 80mm natural stone facing. Do the bocks and facing need to be bound together with butterfly connectors etc?
PS. what other names do (British style) porches have - google searches just bring up endless American open-with-a-wooden-swing style porches?
try and make the cavity between masonry 50mm minimum.
do use wall ties between leaves.
accommodate a 100x100mm timber post in each corner.
try and mimic the existing house roof pitch, soffit overhang and tiles.
don't forget to make provision for rainwater.
Thanks.
Is the cavity best left as a cavity or is there some insulation type (insulation isn't actually important here) material which will provide a better damp proof?
Also, any tips for joining the porch to the house?
a cavity wall has both thermal and damp resisting qualities.
you could install thermabate or similar cavity fill insulation. this will certainly help if you ever wish to heat this space.
as far as i'm aware cavity fill provides mainly acoustic and thermal resistance, though manufacturers claim that their products will not transmit water due to the "wick" effect.
use stainless steel wallstarters as a connection from house to porch.
Thanks for the connector tip.
Doesn't wicking normally refer to things that DO transfer water.
yes it does.
so, the insulation manufacturers gaurantee their products will NOT transmit water, as i said in the previous post.
