Building walls and foundations
17 Jan 2007
Yorkshire
I need to build a 7 ft retaining wall. I was planning on using 4" concrete blocks laid sidewards.
Im wanting to know.
1. What size footing would be required
2. What mix of concrete I should use and what mix for the mortar
Im also building a few raised beds which will be around 1m in height.
Thanks in advance
Andy
Whilst building a 7-foot high retaining wall can be a DIY proposition, its design will not be.
You are effectively building a 'gravity retaining wall,' which will probably need to be a lot thicker than the length of a concrete block, depending on the characteristics of the retained material. You may need to consider drainage (build-up of moisture behind the wall will increase the pressure on it), and your foundation will also need to be properly designed.
Do the work yourself, but make sure it is to a proper design.
