'Built in' Headboard
23 Dec 2002
Glasgow
Stayed at the hilton last weekend and the bed had one of those headboards that was stuck onto the wall. I wondered if anyone knew where you could get the materials, or better still a diagram of how to build one. There did'nt seem that much too it but I am unsure of the upholstery side of it. Ideally I would like to buy one as a flat pack kit that I could mount myself. Ever heard of such a thing?
Try some of the shops like the 'Bedshed' or similar .. it's only a flat headboard with a couple of brackets on the back that you 'hook' over a couple of screws on the wall above the bed
Not sure if this is any help....
My wife is a curtain maker and have made a 2 foam rectangle shape and covered in fabric material with tab over the curtain rail above the bed.
Brilliant, send me the bill and Ill pass on my delivery details and then Ill be in good shape! :p
About £10,000 including free delivery :)
Believe it or not you cannot buy this anywhere ! ( you've thought the manufacter would be keen on this as it so comfortable for back support )
Get the shape foam (not soft type) cut out to your size then pop in any curtain making shop for fabric material with tab to be covered by them,shouldn't cost a lot.If you're having problem then when you're in sunny Southend area drop them in and my wife will make them for you for a couple of drink or 2 !!
Then chose any nice curtain rail to match your bed etc..........
