Hi Oilman , thanks again. Let me tell you whats happening/happened. All of a sudden I got banging in the boiler. I had no drain cocks so laboriously drained, then ran cleaner through, then again flushed the system. .. the problem remained. Also, I noted that every time I drained the system (I have now put a drain cock on the kitchen rad.) air was getting trapped .. this appears to be between my upstairs and downstairs (lounge) rad. so , every time I drain it, I manually drain the longe rad (Which is always cold at this stage) and then (with the pump running) force the air out of the lounge rad flow and return pipes (air mainly in the return), and bingo! The lounge rad is back to normal. However, the banging in the boiler persists. I have put a new pump on (cause the other was fused to the pipes and the the gang valves were bust), and have also put new valves either side of new pump. I also had a 'ticking' .. like a drip, but have had all floor boards up , and there is no leak. However, as well as the banging boiler , I now have a noise (between a humming and a whistle), which is everywhere, ie.. sounds like its every rad and the boiler!! I have no idea what this whistle/hum is about , But the banging only comes in with the central heating.. As there is a motorised valve on the central heating return (not the hot water which joins the return pipe after this valve), its the only thing left to replace !! I would be grateful for any advice.. As you can imagine, as a female, I am losing patience and apart from having cleaned the system and fitted a new pump and a drain cock, I havent made any progress from the original problem , and have now also developed another noise !!! Thanks again.
