I need to install a light with PIR in my Mums enclosed porch however there are no lighting circuits anywhere near to it, I am planning to run a spur from a power ring via a FCU to provide power, however due to the location of a window I will need to run the wiring from the FCU to the light horizontally about 1m above the floor.
Is it acceptable to do this with cable clips, I am planning to use a 3 amp fuse in the FCU and connect from the FCU to the light using 1mm Twin and Earth.
If not can I use plastic 20 mm trunking?
