Cable Size
13 Jul 2004
I want to run 3 300 watt spot lamps outside with 2 2way switches (1 will be 50 meters from the other so potentially 100 meter run for power from 1 switch back to the other). can i get away with 1.5mm 4 core armoured cable or will i need 2.5mm.
You will need a min of 2.5mm, but I would be inclined to use 4mm if you can.
