cable through garden
You are talking about running an electricity supply to an outbuilding that is part of domestic premises?
This is notifiable work under Part P of Building Regs
Look at the Electrics UK forum or ask an electrician.
http://www.diynot.com/wiki/electrics:part_p
I have just done the same thing.
Two choices.
1. Get the work done by a part P registered electrician.
2. Put in a building notice with the council, get an electrician to do the work or do it yourself, then get the installation tested by a competent person. (Normally this would be a qualified electrician but in this case they DO NOT have to be part P registered)
I went route 2, did the work myself then got it tested but I had to put in a building notice for some construction work anyway.
Good luck
What if he just puts a plug on the cable and plugs it into a socket in the house? (with a RCD plug or adapter)
No bregs required then
unless the work includes fitting a consumer unit, of course (which he says it does)
Or unless the cable through the garden is fixed, because if it is then the Building Regulations apply - it doesn't matter whether there is a plug on the end of fixed wiring or not.
