Just a quickie as not 100% sure on this. Old house with lots of code 1's on PIR. Supply to detached garage is in plastic conduit buried in ground. 30 amp fuse from house supplying garage fuseboard fed in 2.5mm singles. No earth from house fusebox but garage is TT, house is TNS. I have reconnected this as part of ongoing project into a 20 amp mcb but not sure if it needs an earth cable running in the conduit. Not wanting to export the house earth but can not see the point of running an earth down the conduit to protect the singles supplying the garage board. The garage is going to be upgraded asap but still doing house at the moment. Mental blockage at the mo so another point of view would be appreciatted.
