Can anyone confirm this is wrong?
Discussion in 'Plumbing and Central Heating' started by noobdiyer, 21 May 2012.
  1. noobdiyer
    noobdiyer
    3 Jun 2011
    17
    Thanks Received:
    London
    Country:
    Hi all,
    We had some work done, and I get the feeling the guy who did it didn't really know what he was doing. Being a noob, I need to confirm my noob logic.
    In the attached image:
    A - waste
    B - from the sink
    C - Fork plastic bit
    D - waste pipe for dishwasher
    http://media.diynot.com/167000_166777_46296_32899282_thumb.jpg
    D is lower than A, so logically, all our waste from B is in theory flowing to D, which can't be right?!?
    As a solution, I'm wondering if I can just:
    - Remove "D"
    - Cap off the right hand side of C with a plastic screw cover thingy.
    - Replace "B" with something of the same length, but with a entry point for the dishwasher (sort of like a T junction).
    The thing which I don't quite get is that the top of "A" has a rubber seal and small lip (about 3mm) which fits into the grey sink waste thing above it. Does this mean the T junction part is not a normal one, or do I need to ask for something special/specific? Also, are sizes/lengths standardised, or should I take the existing part with me for reference?
    I could replace "C" but not sure what the point is if I can just seal off the right hand side with a screw on cover.
    All suggestions appreciated!
    Thanks!!!
  2. Sponsored Links
  3. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    Your noob logic is spot on, get the guy/gal back to do it properly.
  4. noobdiyer
    noobdiyer
    3 Jun 2011
    17
    Thanks Received:
    London
    Country:
    Awesome... I can feel the noob overconfidence building ;)
    To be honest, it's going to be so much bother getting him back in, I'd rather just fix it myself.
    If I take the whole of A,B,C, and D with me to a plumb center or similar tomorrow, hopefully they can sort me out!
    Thanks!
  5. TicklyT
    TicklyT
    30 Jul 2006
    3,481
    Thanks Received:
    337
    Hampshire
    Country:
    Routing the dishwasher waste pipe as high as possible, tight to the underside of the worktop will help prevent any backflow towards the dishwasher. A clip around the D/W pipe to stop it blowing off the spigot would be a good idea too. The hose may seem tight when it's cold, but once the D/W starts pumping hot water through it....
    The union with the sink waste is normal for a sink trap. The joint below it is likely to be a telescopic section with a compression fitting to nip it up.
    A trap like
    [​IMG]
    would be the more usual fitting. It would save a bit of space in the cupboard under the sink too. Normally, the hose adaptor would be swivelled around to point upwards on installation to route the hose as above.
    A pound to a pinch of the proverbial says the trap outlet would be at a different height, so the grey solvent weld pipe would need modifying to change the trap though.
  6. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    But the spigot looking up. :rolleyes:
  7. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,471
    Thanks Received:
    1,761
    Northamptonshire
    Country:
    May get away with just turning the whole thing round 180degrees so D is at A and vice versa. Looks to me like it is swept in direction of flow so is actually fitted the wrong way round.... Could need to trim a fraction off the bottom of the telescopic section (B going into C) to allow for the height difference.
  8. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    Just turn the trap around, don't need to buy no new trap.
  9. noobdiyer
    noobdiyer
    3 Jun 2011
    17
    Thanks Received:
    London
    Country:
    Ah... this was what I was worried about - not too keen on altering the grey solvent weld pipe. Hmm... may have to try and get someone to get this done after all.
  10. Sponsored Links
  11. noobdiyer
    noobdiyer
    3 Jun 2011
    17
    Thanks Received:
    London
    Country:
    Hugh puts forward a good idea, and I think it could work. Will do some reading on how this could be achieved as I've never trimmed down this kind of pipework before - if it's literally just cutting it, then it could work!
  12. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    Yes thats why its an adjustable trap.
    Check first it will probably slide in more anyway.
  13. DP
    DP
    10 Dec 2003
    15,186
    Thanks Received:
    3,374
    Glasgow
    Country:
    B slides in C.
    Remove the trap and hose at D.
    Trim B so that D now line up with grey pipe, Fit hose to A.
    Secure all unions
    Route the dishwasher hose so that it goes up and then comes down to connect to the trap.
    Good trap, no need to get another:cool:
  14. mysteryman
    mysteryman
    5 Jun 2010
    1,664
    Thanks Received:
    233
    Shropshire
    Country:
    Just to confirm the above. The dishwasher waste is connected to what should be the outlet, and the outlet is where the dishwasher waste should be. You've got a telescopic inlet from the sink, so turn it round, adjust the telescopic part to suit, and take the dishwasher waste tight up under the sink before dropping to the nipple. This will prevent back-siphonage.
  15. Agile
    Agile
    26 Jun 2004
    64,039
    Thanks Received:
    4,595
    London
    Country:
    As Hugh says just reverse A and D and hook up the hose.
    I am sorry that he did not do it correctly. There is often a lack of skills in the plumbing business.
    But I put some of the blame on customers who choose whom to employ based on rock bottom prices!
  16. Stokeplumbingandtiling
    22 May 2012
    2
    Thanks Received:
    Staffordshire
    Country:
    seem like you have your answer........but you are not getting the person who did it back. You could at least let them know that you aint too pleased......they may even learn something from their mistake
  17. noobdiyer
    noobdiyer
    3 Jun 2011
    17
    Thanks Received:
    London
    Country:
    Problem fixed - all works perfectly now, and have learned something to boot. Win-win!!! :D
    Never thought about the consequences of not informing the guys who did the job - I'll email them a picture for sure - I wouldn't want them doing that to another customer!!!!
Loading...
Share This Page
