Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi, I did not drain the system I just closed the valves from both sides of the radiators and removed 5 units. I have left 2 radiators on, in the bathroom and in one the bedrooms.
I actually need only the hot water for the bathroom but if I can run the heating on those two radiators left on that would be better.
My boiler is an Ariston microGENUS 23 or 27 MFFI.
Will I be able to start the boiler?
Do I risk to have a leak with only 2 radiators on? or is irrelevant?
