Can I safely take power from porch light pendant for Xmas lights
Status
Not open for further replies.
5 Feb 2005
Wife wants Xmas lights outside front of house on the porch. The only external socket is at the back.
Front porch has a light pendant.
Would it be considered wrong to wire a fcu from the pendant to power the LED Xmas lights? Just a string to go round the porch, a few Watts. Not thinking of Blackpool lights.
Each circuit is rcbo protected.
Just saves me a massive headache but sure its wrong.
Thoughts?
As its rcd protected that’s fine.
Maybe remove your existing lamp and use one of these ?
https://www.ebay.co.uk/itm/B22-Sock...=p2349624.m2548.l6249&mkrid=710-127635-2958-0
Not seen one of those for many decades, I didn't know they were still legal.
If the lights use a 13amp wall-wart, better to install a 13amp socket, adjacent to you porch light - run from that light, but labelled 'Christmas Lights Only'. I would be wary of adding mains powered 240v lights out of doors, RCD protected on not.
Yes. You don’t need a FCU on a lighting circuit. The 6 amp MCB will trip faster than a 3 amp fuse. Just use a bayonet plug in place of the light bulb.
Ah, we still need to use the porch light though
Yes, a wall wart. So you think a well labelled socket and no fcu?
Agreed However using a 1A fuse which are readily available will give the required discrimination.
My 'preferred method, connect it to the permanent power part of the lighting circuit, that way the porch light or the Chritsmas lights can be used independantly.
As above a 1A fuse in a FCU will negate any lighting circuit blackout issue.
Do this, and ignore the forum jester when he objects.
My 'preferred method, connect a 13A switched socket to the permanent power part of the lighting circuit, that way the porch light or the Chritsmas lights can be used independantly.A 1A fuse in a FCU could be added to negate any lighting circuit blackout if you think it could be an issue with the wrong thing being plugged in.
Yes, absolutely! It is the only sensible way, anyway, with a wall-wart.
A 13 amp socket on a lighting circuit is bad practice. Some seem to disagree but it is a fact and common sense.
That is winston1's personal opinion and it is NOT a fact in the real world.
Notice a pattern ? The forum jester has arrived.
winston1's opinion is just that, his personal opinion and not backed up by any regulation or safety bulletin, it is expressly permitted in the wiring regulations and there are very many thousands (if not millions) of 13A sockets fitted on lighting circuits across England and beyond working perfectly safely.
Do you put a 1A fuse in a FCU for each of your lights?
Wall worts are designed to run directly off a 32A ring. They have no cable to protect which is what a FCU is for.
As many have said the regs do not make sense and in this case are clearly wrong.
Status
