Capped gas line, am i being paranoid?
Status
Not open for further replies.
23 Jul 2022
Hi Guys
Had a gas cooker removed a couple of weeks ago, and moved the washing machine out to gain access to the gas line to have it capped,
The wall behind the washing machine is shocking and needs stripping (avoiding the capped pipe)
The pipe near the cooker that attached to the hose was copper, but i am not sure if the remnant is dirty copper or black pipe (the washing machine had not been moved in some time)
I noticed the guy who did it had used white teflon tape to seal it and cut it right back to within 3 inches of the wall. He is definitely on the gas safe register (i checked), he did something at the meter to check for leaks...
I thought you were not supposed to use white tape, or compression on gas, and im not sure its good that the pipe goes through the wall?- although it has been like that for 20 years and may be protected in the wall (i cant tell)
Roll forward three weeks...
I had a different plumber in to service my boiler , also gas safe registered- he also did something at the meter to check for leaks
I mentioned the capped pipe, he barely glanced at it (its near the floor and he stayed upright) and said its fine, and that going through the wall was nothing to worry about
He also said that there are no leaks as he checked the gas pressure and to not worry.
Am i being paranoid about nothing? My mrs thinks i am, and that the idea of me getting someone in to check it is me being ridiculous
5 Nov 2007
You have had two gas safe engineers look at it, one to cap it, one to check it over. I am not an expert but have seen plenty of gas pipes capped with compression and ptfe.
Blup
23 Jul 2022
Yeh i guess i am being silly, it was just the white tape (i thought it was yellow for gas) that triggered me ... i will relax (i am wary of gas) thanks ...i will also stop doing my mrs head in :)
30 Dec 2018
The reel is yellow to identify it, but the tape is still white, just twice as thick thought still PTFE. Put twice as much on and it's the same.
31 Mar 2020
They were checking for leaks at the meter. There is a test point which they connect up to and register if there is any loss of pressure over a period of time.
27 Oct 2009
Don't discuss gas work
15 Aug 2010
Livingston
If you believe you are correct, then you will be able to explain why you hold that belief. I would be very interested to read that explanation.
indeed you would but as this is an open forum the site does not permit me to give gas advice, get yourself qualified and join the CC and I will be more than happy to enlighten you
Status
