    Dismiss Notice
Capping off an old gas metre
Discussion in 'Plumbing and Central Heating' started by els34, 29 Oct 2011.
  1. els34
    els34
    24 Oct 2011
    11
    Thanks Received:
    Country:
    A plumber has cut off the gas pipe so no gas can come in or out and has put an internal cap on it. Is it ok for me to move it and do I need a registered plumber to do it?
  2. Sponsored Links
  3. tamz
    tamz
    25 Feb 2009
    1,884
    Thanks Received:
    278
    West Lothian
    Country:
    Move what?
  4. els34
    els34
    24 Oct 2011
    11
    Thanks Received:
    Country:
    the gas metre
  5. tamz
    tamz
    25 Feb 2009
    1,884
    Thanks Received:
    278
    West Lothian
    Country:
    Why was it capped?
  6. Charnwood
    Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    Not sure what you mean by "internal cap". A picture of the cap would possibly help.
    Are you planning to resite the meter?
  7. tamz
    tamz
    25 Feb 2009
    1,884
    Thanks Received:
    278
    West Lothian
    Country:
    You don't need an picture of an internal cap if you are an RGI so shouldn't offer advice on what you know little about.
  8. Nige F
    Nige F
    28 Jun 2005
    21,204
    Thanks Received:
    1,741
    Country:
    Give some people a metre and they`ll take a kilometer ;)
  9. adlplumbing
    adlplumbing
    9 Dec 2009
    6,341
    Thanks Received:
    998
    Lancashire
    Country:
    so why has he disced your meter then
  10. Sponsored Links
  11. els34
    els34
    24 Oct 2011
    11
    Thanks Received:
    Country:
    A registered plumber put an internal cap on the gas metre as he didn't have the proper cap to put on it, we want to move the gas metre about 1 metre to the left, as we are doing the house up and want to lift the flooring up as well. He also cut the pipe so gas can't come in or out.
  12. tamz
    tamz
    25 Feb 2009
    1,884
    Thanks Received:
    278
    West Lothian
    Country:
    An internal cap or disc is an proper fitting, just a different type.
    He should have removed the meter and pipework at the time. Get him back.
    • Thanks Thanks x 1
  13. els34
    els34
    24 Oct 2011
    11
    Thanks Received:
    Country:
    Thanks, so I can't remove it myself?
  14. tamz
    tamz
    25 Feb 2009
    1,884
    Thanks Received:
    278
    West Lothian
    Country:
    Not really.
    • Thanks Thanks x 1
  15. soubriquet
    soubriquet
    9 Feb 2004
    26
    Thanks Received:
    8
    Yorkshire
    Country:
    All the pipework up to the meter, and the meter regulator, isolation valve, and meter are the property of and responsibility of the gas network/supplier.
    You may not remove any cap on the gas meter, nor may you re-site the gas meter. The gas meter may not be moved by anyone other than your gas supplier's agent.
    A registered gas installer may connect to or disconnect from the meter, but is not permitted to re-site it.
    • Thanks Thanks x 1
  16. els34
    els34
    24 Oct 2011
    11
    Thanks Received:
    Country:
    Thanks for all your comments - I will get my plumber who is a Lloyds register to remove it as according to British Gas they are allowed to re-move it.
  17. soubriquet
    soubriquet
    9 Feb 2004
    26
    Thanks Received:
    8
    Yorkshire
    Country:
    I'm trying to help, but what you say is somewhat contradictory Lloyds register has nothing to do with gas work.
    Your gas engineer would have to be Gas-Safe registered, not just a Registered Plumber, (that confers no rights to do gas work), and he would have to have a specific qualification in domestic meters, MET-1, this would be listed on his ID card.
    However, you talk of moving your meter by a distance of approx 1 metre. It is extremely unlikely that the existing pipework prior to the meter will reach that far. I repeat, your plumber should not alter the pipework prior to the meter, without the specific permission and approval of your meter's owners. It's complicated. Here's what OFGEM say.
    "Can the meter be moved by a Gas Safe Registered engineer?
    It is possible for a gas meter to be relocated without altering the service pipe and ECV and this may reduce the amount of work required, and the cost. However there are some specific requirements that need to be met:
    the Construction (Design & Management) Regulations 2007 may apply,
    GSIUR specifies that ….’when a meter is installed or re-located in any premises in either case at a distance of more than 2 metres from, or out of sight of, the nearest upstream emergency control in the premises'... the gas supplier shall ensure that...’a suitably worded notice in permanent form is prominently displayed on or near the meter indicating the position of that control’, and the British Standard BS6400 (specifies the technical requirements necessary to maintain a safe and legal meter installation).
    An Ofgem Approved Meter Installer (OAMI) or registered Gas Safe Registered installer should be familiar with this and be able to undertake this work and arrange for it to be inspected by an OAMI. A list of OAMIs can be found here.
    However, since the meter installation is most likely to be the property and responsibility of the Meter Asset Manager (MAM) - in most cases this will be your energy supplier - it would be necessary for the OAMI or Gas Safe Registered installer to first contact the MAM, seek agreement for the works to be undertaken, convince the MAM that the work will be properly designed and installed, safe and that the overall long term integrity of their meter installation is not compromised, and finally agree contract terms.
    A non-OAMI Gas Safe Registered installer would need to adhere to industry established and legally required reporting requirements regarding disconnecting and reconnecting gas meters, and arrange final inspection by an OAMI.
    In practice therefore, it may well be more practical for the MAM to undertake the work themselves, using their own established workforce or appointed OAMI. This methodology may well still result in lower costs than undertaking service pipe/ECV alterations."
    If you choose some other route, you are committing an offence punishable by a substantial fine and/or imprisonment.
    • Thanks Thanks x 2
Loading...
Share This Page
