Cavity wall insulation
28 Aug 2008
Fife
Hi
Now I hope this isn't too silly a question but can an upper flat have the wall cavities insulated without downstairs being done?
Also how do you know if it has been done in the past? There are no holes in the outside wall suggesting that it has been added but its a fairly new build so I suspect it would have been put in while being built.
What sort of floor does your flat have Ross?
If its that new i cant imagine that the lower floor walls would be insulated and not the upper floors.
they would have used that solid batt stuff
I am in the dubious position of having had the expansive stuff in the '70s. some of which has collapsed
Its technically possible, but it will greatly increase the chances of condensation or penetrating dampness across the cavity if there are uninsulated walls adjacent (especially above) or if there are voids where some insulation drops.
I don't know about north of the wall, but for us, new builds since the mid 80s will have insulated cavities (or thicker internal walls), or would have required a building regs application or similar for retrospective cavity wall insulation
There should be some plans at the council but no guaratee that it was built to plan - you will just have to inspect the cavity to confirm
Under the floor boards there are what I can only describe as concrete planks, I don't know if they continue into the wall or not.
I've also been told that the inner wall may be made from some kind of insulting block, I'm not sure how to tell though but it is very soft.
Thanks for your replies so far.
the inner wall may be made from some kind of insulting block ...... it is very soft.
And over in Glasgow, the blocks are hard and not only insulting, but downright aggressive too :shock:
Seems like aerated blocks and a Bison or 'beam and block' floor. Neither of which will bridge a cavity
