CEILING LIGHT FITTING!!
2 Jun 2005
Hertfordshire
I've read a recent post on the same topic as mine, But I have a few more questions for you guys to answer and therefore help me!
first of all let me just say what I've done which I'm sure you could determine the solution.
OUT OF THE CEILING:- 3 grey cables each with RED - BLACK - YELL/GRN
wires coming out of them.
Q1. I connected all reds together, all blacks and yell/grn, is this correct?
Q2. How do I determine which BLACK is the switch wire?
THE LIGHT FITTING:- 3 Way connector with BROWN-BLUE-YELL/GRN
Also, out of the actual lights 4 BLUE wires,
4 BROWN - YELL/GRN is connected to the 3 way
connector and also earthed to the plate fitting.
Q1. Once I've determined which Black is the swicth wire do I connect this to the Brown which is connected the the 3 way connector.
Let me just say that I swithed the fuse on and amazingly the lights worked, but once I swithed it off by the light swith the fuse tripped! Now the light swith doesn't work!
Can you help me here please....
To find the switch return cable you will need to use a multimeter & test for continuity between cable ends at light fitting & switch, I would imagine it will be a black (should have red sleeving on it).
Join all reds (phase/live) together in a chockblock. the switch return when you find it goes to the 4 brown wires of light fitting. The other two black (neutral)wires go to the 4 blue wires of light fitting. All earth wires joined together (all should have green/yellow sleeving).
I suspect what you have done is to put the reds to the light fitting browns so making the light permanently on, the two neutrals have been joined to the switch live, now you've pushed the switch & put switch live to neutral tripping mcb or blowing fuse.
Dont forget to isolate the circuit before doing any of the above !
Many thx,
Yep, you suspected right the light is permantly on... Just a few more questions..
Q1. Chock Block, is this a copper connector with 3 holes and screws - so as to connect the RED wires together?
Q2. Connecting the switch wire to the 4 Browns do I use a plastic connector with the screws? Also, do I do the same with a plastic connector with the screws to the other 2 blacks to the 4 blues(neutral)?
Q3. When you say Isolate the circuit do you mean turn off the switch at the fuse?
barrettandy said:
I've read a recent post on the same topic as mine.... I connected all reds together, all blacks and yell/grn, is this correct?
No.
And it was a curious thing to do, given that the original light fitting or ceiling rose would not have been wired like that, and you wouldn't have found a single diagram or description in any topic or any post on this site telling you to do it.
It's almost certainly been destroyed - you'll need to replace it.
//www.diynot.com/forums/viewtopic.php?p=109118#109118
You connect the switch wire to the brown terminal of your light, the other black(s) to the blue one and all the earths to the green/yellow one.
Yes.
Also, see: //www.diynot.com/forums/viewtopic.php?p=75416#75416
About the Ceiling light fitting...
A collegue of mine at work as just informed me that a New law came in earlier this year that if Your replacing any New lights in your house that a qualified electrician as to do it, otherwise your house insurance is invalid...
Does anyone know of this and maybe elabrolate...
Cheers
Andy
Lots of people know of it, and many of them (your friend not included) know what the law really says.
DIY Electrical work and the law
On January 1st 2005 legislation came into effect which brought electrical work in dwellings under the Building Regulations, and made it a controlled service. This amendment to the Building Regulations, known as "Part P", imposes safety requirements, and also classifies electrical installation work into two basic categories, notifiable and non-notifiable.
Essentially the distinction is between major work, or work in what are deemed high-risk areas such as kitchens, bathrooms and gardens, and minor work such as replacing switches or adding sockets to existing circuits. (NB to those with a knowledge of the IEE Wiring Regulations, the term "minor work" is used here in its generic sense rather than the meaning defined in the Wiring Regs.)
A very important and fundamental point to note is that DIY electrical work has not been outlawed. It has been brought within the remit of the Building Regulations and cannot be carried out as freely as it was before, and in many cases cannot be carried out without involving your local council, but you may still DIY.
Major work is classed as notifiable, i.e. it must be notified to your Local Authority's Building Control department (LABC). How this happens depends on who does it.
If the work is carried out by an electrician who is registered with one of the organisations who administer self-certification schemes, (sometimes referred to as "Competent Person" schemes) they carry out the work and report the details to their scheme organiser, who then notify the appropriate LABC that the work has taken place, and that it has been certified by the person who carried it out as being in compliance with the Building Regulations. You may be familiar with this method of operation if you have ever had windows replaced by a FENSA member.
If the work is carried out by someone who is not registered with one of the schemes, be they an electrician or another type of tradesman (e.g. kitchen fitter) who has chosen not to register, or a DIYer, then it must be notified to LABC in advance in the same way that any building work which requires their involvement is notified in advance. And just like when you are building an extension, or converting a loft, etc, there is a fee payable to LABC to cover their activities related to checking compliance with the Building Regulations.
The full text of the legislation can be found here: http://www.opsi.gov.uk/si/si2004/20043210.htm and it is worth making the effort to read it, and understand it, because there is a lot of misinformation on the Internet, some of it put out by organisations with a vested interest in pretending that DIY work is illegal, some of it by LABCs who have either misunderstood the legislation, or who are also attempting to mislead the public in order to reduce the amount of work notified to them by non-self-certifying people, some of it, surprisingly, by the ODPM themselves (The Office of the Deputy Prime Minister were responsible for the legislation), and much of it on electrical advice and discussion fora like this one.
At the time of writing (July 2005), the following work was classed as not needing notification to LABC:
[code:1]1. Work consisting of -
(a) replacing any socket-outlet, control switch or ceiling
rose;
(b) replacing a damaged cable for a single circuit only;
(c) re-fixing or replacing enclosures of existing
installation components, where the circuit
protective measures are unaffected;
(d) providing mechanical protection to an existing
fixed installation, where the circuit protective
measures and current carrying capacity of
conductors are unaffected by the increased thermal
insulation.
2. Work which -
(a) is not in a kitchen, or a special location,
(b) does not involve work on a special installation, and
(c) consists of -
(i) adding light fittings and switches to an
existing circuit;
(ii) adding socket outlets and fused spurs to an
existing ring or radial circuit; or
(iii) installing or upgrading main or supplementary
equipotential bonding.
3. Work on -
(a) telephone wiring or extra-low voltage wiring for the
purposes of communications, information technology,
signalling, control and similar purposes, where the
wiring is not in a special location;
(b) equipment associated with the wiring referred to in
sub-paragraph (a).
[/code:1]
The terms "kitchen", "special installation" and "special location" are defined in the legislation.
Like any law, things can change, and you are urged to ensure that you make yourself familiar with the law as it stands now, not necessarily as it was when this document was written.
The starting point on the ODPM website for information related to Building Regulations is http://www.odpm.gov.uk/stellent/gro...ments/sectionhomepage/odpm_buildreg_page.hcsp and a list of the relevant legislation can be found at http://www.odpm.gov.uk/stellent/groups/odpm_buildreg/documents/page/odpm_breg_600270.hcsp .
It is in the nature of the Internet for sites to change, and it may well be that today, when you are reading this, the links above no longer work, and you will have to search for the pages you want.
Useful Information
On the ODPM website there are a number of "Approved Documents"
( http://www.odpm.gov.uk/stellent/groups/odpm_buildreg/documents/divisionhomepage/br0041.hcsp ). These are not definitions of the law, nor do they tell you what you must, or must not, do. Instead they give guidance on ways in which the law can be satisfied. They do point out that you are not obliged to adopt any solution contained in them if you prefer to meet the requirements in another way, but that said they are useful as they contain common sense advice and often there is no good reason not to adopt the solutions they contain.
Approved Document P can be found here: http://www.odpm.gov.uk/stellent/groups/odpm_buildreg/documents/page/odpm_breg_br1007.pdf .
Technical Requirements
The technical requirements laid down by Part P are remarkably simple. They are:
  1. Reasonable provision shall be made in the design, installation, inspection and testing of electrical installations in order to protect persons from fire or injury.
  2. Sufficient information shall be provided so that persons wishing to operate, maintain or alter an electrical installation can do so with reasonable safety.
It is worth noting however that they apply to all work, not just notifiable work, no matter who does it. So a DIYer adding a socket or a fused spur to a ring final circuit must work to the same technical standards as a registered electrician doing a complete rewire.
The biggest practical issue that arises is testing. To carry out testing of electrical circuits requires expertise and equipment, neither of which are likely to possessed by the average DIYer. So although Part P allows a DIYer to replace an entire circuit cable if it is damaged, without notification, it is arguable that he could not be sure that he had done it properly unless he carried out a series of tests on it, something he would probably be unable to do.
The IEE Wiring Regulations, aka BS 7671
Surprisingly, perhaps, Part P does not alter the status of the Wiring Regulations. They are still non-statutory, and there is still no legal requirement to adhere to them in domestic installations. This is a source of great discomfort to many electricians, and some of them will jump through hoops to try and prove that they are mandatory, but the fact remains that they are not.
HOWEVER, adherence to them is a very good way of ensuring that you meet the technical requirements of Part P, and you would need a very good reason, and a very good understanding of what you were doing, to decide to not adhere to them.
I'm very sorry, but if you don't know the meaning of the word "isolate", you will find this kind of work taxing to say the least.
Why have you embarked on a project you know very little about before arming yourself with some knowledge?
First of all let me just say that i'm a first time DIYer and entering a forum such as this one is very helpful not just for myself but for any other enthusiastic DIYers.
Forum members, professionals and tradesmen like to share their knowledge as I would with my Graphic Design skills in TV.
By being sarcastic, is not very informative but I appreciate and understand your comment.
Knowledge is power!
