cement weld big pipes
10 May 2006
Hi guys. Does any of you know any tricks of the trade on how to apply cement weld around a 110 mm soil pipe quickly so that it can be pushed all the way into a 110 mm fitting before the glue dries? I have used cement weld to join together 32 and 40 mm pipes with their correspective fittings no problem but i am a bit anxious about joining together big pipes as the brush that comes with the glue is fairly small and i might not be quick enough to join them together in time and i'll have to kiss good bye to the fitting and pipe. Thank you very much for your advice.
Get a bigger brush and apply liberally inside the female coupling.
The little brush is fine, just keep spreading it thick on the inside of the socket and outside the pipe, when both surfaces are fully covered push it together with a slight twisting.
You still need to get it in the right place first time, or use weld/o ring fittings, weld one end O ring the other.
Get a pot of solvent cement made by Black Swan. Instead of a brush being attached to the lid they have like a round sponge which is much better, you can apply more glue without having to keep dipping in the pot!
You should be able to buy from a local plumbers merchants easy enough.
