Hi...anyone who can help!
We have recently had problems with our central heating system. We noticed a few weeks ago that our radiators were no longer heating up, apart from the one in our bathroom, so called a local plumber out for a look.
He confirmed that the pump was working (if a little noisy) and we had hot water in our taps so he thought it could be either an air or a sludge problem. He arranged to come back another day to drain the system so that he could learn a bit more and duly did so. Unfortunately after doing this he thought he may have moved some dirt as the boiler was no longer getting hot water up to our tank in a cupboard in the bathroom.
He said to leave it for a few days then try firing it up again in the hope that any air may have worked it's way out but that we shouldn't hold our breath. He also said that his recommendation was for a new system so I asked him to do us a quote for various options. That was last week and is the last we've heard from him. To his credit he's not charged us for either of his visits but I am also getting the impression that he doesn't want the job of sorting us out as I've tried 'phoning him on numerous occasions and he's not taking the calls.
Also, last weekend, I drained the system myself and added some X400 sludge buster before refilling (following good instructions) but so far this has had no effect.
So our current situation is as follows:
No heat to radiators except bathroom
No heat to hot water tank
Boiler (non combi: Halstead Best 50) fires up OK but as soon as water has reached temp it shuts itself down (I think you can hear the water heat, then boil, then boiler switches off and you hear the water drain back?)
I am trying to get a handle on options of what's likely to be the cause before getting another plumber in. I've read that we should be OK with our microbore pipes, system-wise, but don't know if a power flush would sort it out, or if we need a new boiler - if so fine, we're just a bit frustrated at being left high and dry.
I hope that someone out there can offer some advice
Thanks in advance
Andy
Thanks in advance
Andy
