- Joined
- 17 Sep 2006
- Messages
- 9
- Reaction score
- 0
- Country
I've got a 'Potterton Suprima' central heating boiler - it was installed by the original house builders a couple of years ago.
The digital programmer that was installed as standard was a EP2002 - a simple 1 cirucit combined heating + hot water controller.
What I want to do (to save masses of gas bill money), is to replace this programmmer with a Potterton EP6002 - a dual circuit controller. Which will allow me to independantly program the centra heating and hot water circuits.
This will stop me from having to constantly turn off the hot water circuit as I've proved through testing that I only need to heat the water for 1 hour a day to supply all the hot water in the tank that I need for a day.
I'm confident with electrics etc and I believe all that will have to be done is replace the current programmer and wire in the new unit, ensuring that the hot water and central heating circuits are wired to the correct terminals.
Here's the big question - under all these regulations that we are supposed to live under - corgi / IEE etc, can I legally replace this programmer by myself?
I don't believe changing 'just' the programmer effects any of the central heating or boiler installation regulation as it's just the means of supplying the power to the two circuits i.e. if the fused spur switch was to fail - it would be a like for like replacement.
Here I'm performing a like for like replacement by the same manufactured but it just adds more functionallity.
Look forward to any comments / suggestions.
Phil.
Phil.
