My system is an E.L.M Le Blanq combi boiler.
The water heating is working fine but no central heating.
Problem started this week when I tried to switched the central heating system back on via the temp controller on the boiler, my system has always been on constant but the setting as been set lower so the central heating has not started up, I altered the setting to 3 this week from 1 due to cold nights setting in the system sounded as if it had started up so I thought it was Ok but the radiators did not warm up, on checking the boiler it sounded the same as if it was working, but where the pilot light is I could see that the main burners were not lit, I altered the temp setting down and this switched the boiler off on altering back up it sounded as if it had started, but again no main gas light inside the boiler the pilot light was being drawn in but no main ignition on gas, I tried the hot water and this was fine main gas ignited inside the pilot light viewing window, when I switched the water off the central heating sound had gone off, I altered the temp up until it got to 6 from 3 and it started up again but no main ignition. seems when the water is on this alters the temp setting on the central heating side off the boiler ?
I would like some info from you guys if possible before getting the engineer out.
Cheers Al
Cheers Al
