Central Heating Pump Speed
5 Nov 2008
Dear All
I seem to be getting lots of air in one rad which I imagine is the highest part of the system.
I have a traditional heat only system boiler with heating pump in the airing cupboard.
There is 11 rads on the system.
Could the pump be causing air in the system? its set to number 3 on the selector.
Many Thanks
Yes, it might be the pump causing the air issue but other problems are more likely. Pipe configuration, corrosion (gassing)........
