    Dismiss Notice
Central Heating, why?
Discussion in 'Plumbing and Central Heating' started by MarkFish, 20 Sep 2011.
  1. MarkFish
    MarkFish
    24 Aug 2011
    126
    Thanks Received:
    London
    Country:
    Why is Gas central heating better than putting an individual electric heater in each room?
  2. Sponsored Links
  3. Diyisfun
    Diyisfun
    15 Jun 2004
    7,234
    Thanks Received:
    282
    Norwich
    Country:
    who said it was?
  4. MarkFish
    MarkFish
    24 Aug 2011
    126
    Thanks Received:
    London
    Country:
    Well most homes have central heating. There seems to be a general assumption that CH is better among people I talk to. So I guess most people do.
    The more I think about it the more I think individual heaters are better. You put them in the loft for the summer months. Maintainance is nothing more than a trip to Argos to replace the broken heaters. You get every room heated at the time and temperature you want it.
    I'm sure CH is cheaper to run day to day and improves resale value of the house. But are those the only advantages?
  5. Jake1886
    Jake1886
    28 Jul 2010
    470
    Thanks Received:
    44
    London
    Country:
    Give it a try this winter.
  6. flameport
    flameport
    10 Mar 2007
    9,739
    Thanks Received:
    1,934
    Poole, Dorset
    Country:
    Compare the cost of gas and electricity - there is a massive difference.
    What about your hot water?
    Is the electrical system in your home really up to having individual electric heaters in every room, all on at the same time? (along with all of the other electrical stuff which you have already got)
    If you only heat individual rooms, this won't work in the way you expect - the heat loss from the heated room will be significantly higher due to the lower temperatures of the surrounding rooms. You will therefore require substantially more power to heat that room.
  7. Morrisman
    Morrisman
    13 Jun 2007
    69
    Thanks Received:
    2
    Country:
    If you only intend to use one room a single heater is ideal, but if you have a family, and you actually use a house like normal, moving around, going to various rooms, going to the bathroom etc, then central heating is by far a more efficient, sensible, cheaper way to heat your house.
  8. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    What people fail to appreciate is that traditional central heating warms up the contents and structure of the house as well as the air inside the rooms. There's a huge mass of material there to bring up to temperature (think how cold the car is in winter when you first jump in) and that takes several days; which is why the CH has to work so hard when you get back from a winter holiday. Individual electric heaters will heat the air in a room quite quickly but a traditional CH system has pipes running under floors and generally warms the structure much more thoroughly.
  9. Sponsored Links
  10. xr4x4
    xr4x4
    1 Oct 2009
    3,159
    Thanks Received:
    290
    Hampshire
    Country:
    Also the thermostats on electric heaters are useless... How can they work correctly...they are inside the heaters.....!
    I've modified ours to use external thermostats.
  11. Norcon
    Norcon
    17 May 2008
    8,417
    Thanks Received:
    357
    Country:
    Central heating is only a recent innovation for the colder climates of western nations for the high numbers of the less hardy and sickly homosapien species.
    When the fuel runs out, they'll die off or kill each other through war and a stronger species will emerge.
  12. Morrisman
    Morrisman
    13 Jun 2007
    69
    Thanks Received:
    2
    Country:
    Hell yes. Real men go out and chop a tree down to warm up in the winter. :LOL:
  13. Boilerman2
    Boilerman2
    10 Jun 2009
    5,225
    Thanks Received:
    1,015
    Suffolk
    Country:
    It must get very cold in the Phillippines!! :LOL:
  14. Morrisman
    Morrisman
    13 Jun 2007
    69
    Thanks Received:
    2
    Country:
    Hell yes. Why just last month I had to get up in the middle of the night, a couple of times, to turn off the air-con. :D
  15. Corgigrouch
    Corgigrouch
    13 Dec 2007
    4,009
    Thanks Received:
    512
    Country:
    But only with a saw or an axe.... If you are caught with one of them new fangled chain saw thingies folk will point at you and laugh calling you a homosexual.
    The real problem of heating homes is the lack of insulation.... Even modern UK standards is inadequate in my opinion..
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
