Central heating
22 Dec 2007
the last 2 rads on our central heating system have just gone cold
the feed is hot but the return is cold
the boiler fires up initially and gets quite hot, then altho making a noise it does not appear to be working
the rads upstairs are all hot, even one in the same room as the boiler which does not normally get hot
have turned down the stats on all other rads and turned pump speed up to 2
would be really grateful for any thoughts
Turn pump up to 3 and do a search on here for balancing rads as a starting point.
Thanks, my pump is a myson 2 speed, at the moment it is set on 1 should i turn it up to 2
