HI guy's .
Need a bit of Advice/Help ..
Last night my partner heard a very strange buzzing whiring noise coming from what i now know is the "mid position actuator" .
Now before looking or knowing what this was my partner thought she had knocked maybe a lever that is on the side of the unit (little black plastic lever) with the markings "W---M---H" So i thought i thought i'd try moving this lever to another setting it was currently on W so i moved it down with a little force and it made a forceable click and dropped to the H (thinking to myself it gave resistance and maybe i shouldnt have done that
Anyhow we left it over night the buzzing had stopped but this morning we have found we have no hot water or heating
(knew i done something wrong and should have looked it up before touching ) .
Now from diving into the net and ready up on thing's here and other site's . i have found the pump is very hot and think this is probably due to what i have done to the actuator (probably now not working ) .
I have looked up the model and found it to be a "drayton mid position actuator MA1" and wanted to know what i need to do to replace it .
Could i isolate the power from main's get a new actuator removing old one replacing the wiring one by one with new unit , Have read that the old unit remove's by clicking a button and it detaches from pipe's but do i need to drain the system first ? as was going to leave the old base and pipes and just replace the plastic unit .
Hope you understand what i have written and look forward to a quick reply if possible .
Btw how would i know wich size it is as i have found a 22 and 28m on sites but nothing on unit that i can see tell's me wich it is ?
